RetroGrouch
Short answer? Install the BB in accordance with the frame manufacturer's instructions. If those don't exist, follow the BB manufacturer's instructions. For example, Wheels Manufacturing specifies grease for steel and aluminum frames, PTFE/teflon for carbon frames, and anti-sieze for titanium frames. They also specifically state that retaining compounds or epoxies void their warranty. You also get the following disclaimer in their instructions. "Due to the wide variety of frame manufacturers, Wheels Manufacturing cannot guarantee compatibility with all frames. Please consult with your specific frame manufacturer before installation."
Grease functions well enough as anti-seize and will keep out water but a poor press fit will eventually move grease out of the joint as parts move. Grease masks the noise if/when parts move until the grease is gone. That same relative movement wears out the BB shell making for a looser press fit over time and more noise. This is why I recommend bearing retaining compound when possible.
Press fit BBs are great until they aren't. The PF failure rate (of the press fit, not the bearing itself) is probably pretty low, maybe 10% or less if I had to pull a number out of thin air. Unfortunately, you are screwed if you are in that 10%. My limited personal experience resulted in creaking after a few hundred miles even though I pressed the BB into a greased BB92 shell of an aluminum frame using a threaded rod tool with mandrels sized to press on the outer bearing race. They very same cups, pressed into the same frame after cleaning, with a bearing retaining compound, seem to be silent after a couple hundred more miles. Only time and miles will tell if my fix is permanent. If the green stuff fails, I will install a thread-together BB which is available for 24mm spindle cranksets. 30mm crankset users do not have that option. Yes, Wheels MFG may "void" my warranty, Magnuson-Moss warranty act or not, but bearings are cheap enough. I understand why they don't want the user making it more difficult to remove their BB. The cups are fairly thin wall aluminum. Green Loctite can require some heat to remove without lots of additional force. Epoxy would be even worse.
The lack of good tolerance specifications for the BB itself and reaming a BB86/92 bottom bracket shell is probably the root cause of most of these problems. If I look in my Machinery's Handbook 22nd Edition, and pick an ANSI FN1 fit (light drive fit), I see a range of interference between .0004 and .0014 inch (range of .0010) for a shaft size 1.614 in (41mm). If I had to guess, I would say that is a huge range from "tap it in with a rubber mallet" to "hammering the crap out of it". I would pick tighter tolerances after determining what works for the worst case clydesdale hammering up a 20% slope with a 22T chainring and a fully loaded bikepacking rig for 5000 miles. Is there any chance the overseas manufacturers did similar homework when determining press fit tolerances?
Here is a tolerance for a BB92 shell from FSA courtesy of QBP. https://qbp.com/diagrams/TechInfo/FSA/externalbbfitchart.pdf
41mm -.010/-.040 or 40.96 to 40.99 which is a range of ~.0012 inches. That BB shell tolerance range alone is more than the range of an FN1 fit. Add in tolerances on the BB cups and press fits get ugly quickly. Tighten up the tolerances if you want more reliable press fits.
Spend a couple hours reading the frame building forum on mtbr.com for lots of real world experience discussing the issue along with a couple unhinged rants dismissing those with creaking.
edit: math error
edit: math error
