Cole
You referring to mini splits?I heat my home with two heat pumps and a fireplace insert/I rarely have to use both heat pumps
You’re more than welcome to come over and check them out
I have a wood stove to help also
Thanks all...
Of course my my oil tank is 7/8 full.... And it's a Roth tank. I believe it was installed in 2018. I wonder if I'll be able to sell it
If I still had the resources I'd be interested in the oil. Should be an easy sale, priced right.Thanks all...
Yeah, my guess is the oil company may buy it back after the pump it out...If I still had the resources I'd be interested in the oil. Should be an easy sale, priced right.
Mm y question was on the tank. They are double lined tanks, wonder if the warranty is transferable
Perfect. Thanks!10° F and heat pump's doing just fine.
Would it cost more for two zones? You could save quite a bit in heating costs for bedrooms vs living spacesPerfect. Thanks!
Sounds like they will be using a 48000 BTU unit.
