Going Long and Hard.
Braap. Surprisingly, was able to start last, almost 1.5 hours back, ride through the entire field, run FTD, and set a new course record. Without gears and with tired legs. These are good signs of proper fitness level heading into the race held in the state formerly known as Kansas.
42x16. A little spinny at times but it's the smallest freewheel I can run on this hub and White rings are $$$
Kansas or NJ?
Realized after getting back on this bike that I hate flared bars. So I swapped them for ones that are not after work.
I also realized none of my frame bags fit this bike so I need to figure some poop out. I need to walk the line of bringing nothing, and also bringing everything I'll need for a 350 mile self-supported ride.
I think that's a terrific all-around gear; I ran that exact combo on my fixed gear for years. Now set up with a 44x17, which is essentially the same gear inches.
A real question: Why a freewheel and not fixed for these central/southern Jersey routes? Do you think being able to coast saves some legs?
I have it set-up free for up here where I can't spin fast enough on the descents and need to coast, I do have a 15t Fixed cog that probably would've been perfect.
So yeah, these tires are dope. I don't quite understand how something with so many knobs is so much smoother and faster than a Gravel King, but they are. I really like the standard 43c Gravel King SK but absolutely hate how the Plus version rides. Like brutally stiff. These are still supple with the Endurance casing. Like magic.
It's not an MK5 with a ton of parts thrown at it doe.
I should probably sell it soon as I'm already at 35k miles. That's about the half-life of a VW.
I did my first motor at 38k. At the point the car was bone stock minus coilovers.
Easy 40 before work to test the new bars. This is something I should've done long ago but I really wanted to buy into the whole flared bar trend. Being that I also went to a 44 from a 42, I need to shorten the stem by 10mm.
Going to set the bike up with fork cages and mount my eTrex to test during this weekend's 200k. I also have a Shutter Precision hub coming to lace into my 303s. Mostly because I need more light than the P-Tec puts out and need to race through the night.
Still not 100% on gearing. The route profiles are all over the place in different mapping programs. Everywhere from 11k - 18k. Might be worth figuring out a dingle cog just in case. I've been on a 40x18 with 700x48 tires and a 40x17 with 43c. Generally gets me around 16mph average around Bedminster, which is usually 800ish feet per 10 miles. Kansas is around 400-450.
Fin. This was a good test. Obviously the gearing is a tad tall for this route but I wanted to see if it was doable. I had to walk 2 climbs that were about 12 or 13 percent. Not terrible. Legs never shut down, no cramping or anything. I might run a smaller tire. I've watched so many YouTube videos and no one has ridden anything over a 43c.
