Woody doesn't need to slow down.
Well there ya go. Instead of running 2 awesome brakes that will more than likely fail, I'm going to one shitty brake that barely works from the start. The only good side to this is that my bike is a pound lighter. And I've decreased my drag by 50%
Most guys don't run a front brake. Some because they run a generator hub and the brake doesn't fit. Most because the brake just doesn't matter in snow, you stop pedaling, you stop moving, there's no coasting in these things.
I am slightly worried about getting used to it though. I use the front brake more than my rear. Might swap the lever to the other side.
If I've learned anything about woody through the dozen words he says a day it's that the reason his SS has mechanical brakes on it is because he already owned the brakes. Woody don't upgrade shit unless it's really broken, and it's raining.Woody has hydro's on his FB.
...I told Woody his brother needs to buy a FS carbon bike and leave it at his house.Woody don't upgrade shit unless it's really broken, and it's raining.
After a hefty conversation with my Sram buddies, we decided it would be best to run a mechanical over a hydro. My rear brake failure was 100% caused by the seals shrinking from the cold. With windchill on Sandy Hook Saturday where my brake went out, the temps were probably -20/-30, well below operating temp for hydros. Sram already sent me a brakeset for the ITI that I was supposed to be riding this whole time but the Guides are so god damn nice I've been holding off.
1000% Woody is still using those tires that had a branch go through them...just because they still work I guess.Woody don't upgrade shit unless it's really broken, and it's raining.
I mean in alaska, ok ill buy that it could get that cold...Not in NJ this past weekend to cause o-rings to reach minimum temps. Since srams use DOT 5.1, I would imagine they are using either nitrile, viton, or silicone o-rings....all of which are rated to -20, -35 and -60 F.....only humans feel wind chills.... Ask your sram friends if they would like to revise their bullshit story 😉
My bikes sit in an unheated garage and always have....never had a hydro brake failure due to cold weather.
I got 2 stories from Sram. One was the Company line of 0-100 degrees temperature range for all of their products. After probing him more I got to a guy inside who's their winter racer guy and got a few tricks to make the brake hold. But, that dude runs a BB7 because he's had his brake fail. Cold related or not he stressed the ability to service in the field because it's a long walk to Finger Lake and there are no roads for someone to get you. I ran the Guides at Tuscobia and JayP and had no issues, nor have I ever had any issues. When I started riding for Sram they sent me those BB7SLs specifically for the ITI.
Yeah but.
poorly designed o-ring joint, 30f
I bet NASA specs a better oring than sram. They probably use the same assortment box from harbor freight that I do.Agreed I dont imagine you are going to be needed ridiculous amount of braking power? Why even take a chance....I just used to get the wind chill thing often when designing PRV's for use on oil platforms in the North Sea....They would ask me to spec an o-ring for a valve seeing a windchill of -100 🙂
Fixed that for you
Fixed that for you
