Any electricians in the house? I need to replace a dimmer switch but the new dimmer wires are different colors than the old one.
Old one: black, red, white and yellow. No ground as far as I can tell:
New one: black, red, red/white, green (ground)
The switch is in a three gang box and is also controlled by another switch across the room. I’ve replaced switches before but usually it’s a simple matter of matching wires. Not sure which ones to match in this case. Any guidance appreciated.
