Mtbdog
Pat going off the remote switch I'm guessing it's a Lightolier zpr3.
The black from the new dimmer doesn't go with the group of black wires but with the black wire that originally was connected to the red wire of the original dimmer.
The 2 red wires of new dimmer goes to red and white of 3 wire.
Okay with the schematic of the dimmer I see what's happening.If the new dimmer isn't lighted, disregard the white. Disconnect it from the group of white wires. Put the rest of the white tucked away in the box, won't be needing them. The black wire from the new dimmer goes to the group of black wires,the other 2 wires it doesn't matter which one goes where,they are the "travelers". Then ground it and your good. Always turn power off when installing a dimmer. To get the dimmer to fit in the multi gang plate take the side pieces that say "turn off power " off dimmer for best fit.
