Bought this bike in Feb of this year for $2589.99. I have only went riding a handful of times and the bike remains in great condition. It has been kept in my temperature controlled basement when not in use. Before taking it out I applied frame protection strips. I provided specs from the website below and the only change I have made was the upgrade to tubeless.
You can call or text me at 732 - six eight two - one two eight five
FRAME
Series 4 6061 Aluminum, 29" Wheels, Superlight Aluminum Frame, Flat-Mount Rear Brake, Internal Shifter and Dropper Post Routing, 148x12mm Boost Thru-Axle
FRONT SUSPENSION
Fox 34 StepCast, 120mm Travel, Alloy Tapered Steerer, Air Spring, 110x15mm Boost Spacing, Kabolt Thru-Axle, 44mm Offset
RIMS
Marin Aluminum Double Wall, 29mm Inner, Sleeve Joint, Disc Specific, Tubeless (I set them up tubeless already)
HUB, REAR
Shimano, 148x12mm, MicroSpline, Centerlock Disc, 32H
DERAILLEUR, REAR
Shimano XT 12-Speed
SHIFT LEVER
Shimano SLX 12-SpeedCRANKSET
FSA GRID, Modular 1x, 32T Direct Mount Chainring, MegaTooth Technology, Mego EXO Spindle, Boost Spacing
BRAKE, FRONT
TRP G-Spec FMR Hydraulic Disc, 180mm Rotor
BRAKE, REAR
TRP G-Spec FMR Hydraulic Disc, 160mm Rotor
SEATPOST
TranzX Dropper Post, YSP23 w/ 1x Remote, Size S 125mm Travel, All Other Sizes: 150mm Travel, 30.9mm
FRAME
FRONT SUSPENSION
RIMS
HUB, REAR
DERAILLEUR, REAR
Shimano XT 12-Speed
SHIFT LEVER
BRAKE, FRONT
BRAKE, REAR
SEATPOST
