Lol'ed at adding pressure to reduce pedal strikes.That is a 1/4" difference in length, so the seat goes up 1/4". At the top, the knee doesn't come up as far (if i'm picturing it right,
it is 1/2" less) - On my fatbike, this might be more comfortable because i'm running the seat a bit low because no dropper.
mechanical advantage is reduced - not sure 3% makes a difference.
Never thought about the pedal strikes - i just thew a few extra psi in the shock to reduce sag.
You're picturing it wrong. The knee comes up only 5mm less (1/4" is a about 6.25 mm).
i am switching from 175 to 170 tonight.
I'm going 170 on my current build long low and slack needs that
but if i move the bottom up, then move the saddle up to maintain an optimum bottom location, then isn't the result at the top 1/2" ?
if i didn't move the seat to adjust the bottom, then sure. but then again, i might have to move the seat forward a bit if there is more post sticking out....
so that changes stuff too....ugh. anyway - i'll give it a try on the next round of stupid purchases.
I thought that's how you go blind or am I mixing it up with something else?After a few years the end of the crank arms wear down at least 5 mm
I think it's the bottom bracket that tends to sag with wear.I thought that's how you go blind or am I mixing it up with something else?
There has to be a mechanical advantage or disadvantage, length of lever and stuff.
Pat?
@Blk06CompIRL had 165’s on his new build and it felt like a hamster wheel. You couldn’t generate any power on a punchy “up” move. He swapped them out for longer but was also running a tiny front ring which also was changed. So I’m not sure which was ultimately the main reason for the odd feel.
