2018 Yeti SB5+ TURQ, Medium, Custom Build and Graphics SOLD!
Status
Not open for further replies.
Mr.Moto
SOLD 2018 Yeti SB5+ TURQ Medium. Custom built from ground up. 28 lbs. This frame fits 27.5 Plus wheels or 29" wheels. Bike has seen limited use and is in super condition. Custom graphics on bike, fork and shock. Frame protector applied to the frame since new. Ready to ride and will be sold with a number of extra options. Pedals not included.
This bike is incredibly versatile. It can be set up as either a 150mm / 127mm travel trail bike or a longer travel 160mm / 140mm machine using the Fox Float X that is included. The Works Component headset provides an extra 1 degree of headtube angle. The changes make the geometry similar to the SB 140 or SB 130 Lunch Ride. The bike will come with two Fox Factory rear shocks. Fox Factory Float DPS =127mm and Fox Factory Float X=140mm travel. (Frameset clears 140mm rear travel with plenty of room to spare at full compression with SB5.5 shock rebuilt by FOX and tuned for the SB5+) Both shocks have mounting bushings for the frame to swap in minutes for travel and Geometry Change as desired.
Only signs of wear are minor heel scuffs mainly on the seatstays and they are on the frame protector. One rock scratch on the rear seatstay but it is on the frame protector material. Rubber downtube protector (replaceable) has some scuffs as well. Most of the other wear is on the typical components – derailleur, cassette, chainring, crank arms, grips and saddle. Frame is really in great condition.
Components:
- Works Components -1 degree Headset
- Fox 34 Factory Kashima with 160mm Air shaft. 1 micro spec of a silver spot on stanchion that doesn't affect anything with the fork and barely noticeable as seen in close up pic. 150mm Air shaft included as well if you want a 150mm fork.
- XO1 Eagle Carbon crankset with custom matching Silver and Clear Guard.
- GX Eagle 12 speed derailleur, cassette, shifter, chain
- One Up 30T chainring
- Race Face Next 35 Stealth 20mm Rise 760mm Length carbon handlebars and matching Turquoise Ergon Grips
- Race Face Atlas 35mm/35mm stem.
- Guide RS Brakes with New 180mm HS1 Rotors Front and Rear
- Fox Transfer 150mm Stealth Seatpost with Wolf Tooth Components lever
- 27.5” Raceface ARC40 15/110 12/148 Wheelset with XD Driver, with Bontrager XR4 Team Issue tires, Set up tubeless
- Stock Yeti Saddle.
- Custom SLIK Graphics added to Fork and Shocks
- Custom Vinyl Silver/Turquoise Graphics and Clear Frame Protector Guard added.
27.5+ or 29" wheel capable.
Stock Geometry: 127mm rear and 150mm front travel with a standard headset: 67.1 HTA
Stock Geometry: 127mm rear and 150mm front travel with the Works headset: 66.1 HTA
Geometry with Fox Float X shock : 140mm rear and 160mm front travel with the Works headset: 65.6 HTA
You get the complete bike along with an alternate rear shock and mounting hardware for quick swaps, two air shafts for the Fox 34 (160mm installed), Infinity Switch grease gun with grease, spare derailleur hanger and Sram 34T chainring.
SOLD!! $3,900 obo for complete bike and extras. Pedals not included.
C943AB5D-D9C8-485A-8F11-397E2F4B98FA.jpeg212F41C0-CB59-4F41-986D-9AE27223081D.jpeg4FAAA6D3-820E-4D05-9042-8F291C2D08BB.jpeg88CBD07A-6899-4CC8-85BA-F9710A8A2D5C.jpeg6037F3F3-EFAF-42A3-81B2-6764838BB7EB.jpeg90A4BCBA-B5AA-441F-97F3-35F8C6D18379.jpeg5EC3AC4C-D6E1-4044-A268-58D62CCC773D.jpeg7E45C973-62BB-425E-ABA7-F041B0BEC4A9.jpegE69F058B-7428-43D5-9372-DBF67475AD97.jpeg
Status
