The DIY thread - DIYourself
Today's project - clean up the f'in mess.
i didn't notice the sump pump was plugged into a gfi slave outlet. of course it popped just at the right time
while the water softener was rinsing........
I poked around a bit in the electric code and forums
The exception was removed in 2008, BUT,
Dedicated circuits to pumps and sewer ejectors do not need GFI protection.
There are questions about outlets that are not easily accessible (ie an outlet under the sink for
DW and plumbed garbage disposal.)
In shared circuits, there are power-off alarms, which are great when you are not home,
suppose a water sensor might be a good idea....
And even more strange is that 240v circuits do not need GFI protection, so you can run your welder underwater.
and as a bonus, my sewer ejector failed a few years back. wasn't that special?
Catching up on last weekend's project...
Over a year ago I began building a new drawer box for one of my kitchen drawer. I glued it up last February and it hasn't done much since. Well the old drawer finally shit the bed completely, so I had to sand it up and get it mounted. Decided to go sans finish because I didn't have time to let it fully cure before putting it to use.
Decrepid particle board box
Catching up on some more projects...
The task lighting in my kitchen has always been crap, just a single fluorescent fixture over each side of the kitchen. One of them finally crapped out, so I had an excuse to update. After a bit of research, I found HD had a pretty inexpensive tape light setup:
I suspected it was manufactured by Armacost, which was confirmed when the box arrived with Armacost as the return address. I also found this Armacost channel and diffuser kit, and for an extra $25 I went for it. My cabinets are old, and the likelihood of the tape light adhesive sticking to them log term was low, so then diffuser kit solved that:
Add some extra connectors for good measure:
The install was pretty straightforward:
  • Measure and cut the tape, channel, and diffuser cover.
  • Connect up the tape strips (I mounted 3 separate sections) using the included connectors
  • Lay it all out and test
  • Stick the tape to the channel
  • Hand wire the power supply
  • Mount it all up under the cabinets
  • Manage the wires.
I was going to shorten the wire from the power supply, but I ran out of steam and just decided to zip tie it and be done. I need to get some screw in wire clips to hold the wires in place. The included stick-ons are not going to last with the amount of instant pot cooking we do.
Light kit
Channel and diffuser kit (missing the diffuser in this pic)
How to hacksaw outdoors when your toddler is asleep
Tape in the channel
All done
  • Manage the wires.
Light kit
Tape in the channel
All done
Thinking about doing this myself as well. Is that the 60 LED strip or the 120? Is it bright enough?
60, and they are plenty bright. I might even dim them a step or 2 since the the power supply is dimmable via include remote. Thankfully it remembers the last setting, so if you hard wire it you can toss the remote in a drawer and forget it.
One thing that's slightly annoying is a ~1-2 second delay in the lights turning on when you hit the wall switch. Not sure if that's due to a cheap power supply since it's an inexpensive kit, but it's worth mentioning.
cause you are switching the input to the power supply, rather than the output.
worth it for $$...
installed these at a client, worked out great.
