serviceguy
Interesting, according to the calculator I am between endomorph and esomorph, just like I am always in between bike size...@Paul H
That chart is kind of simple, you should also be looking at your body type
(i found this calculator for it, answer some questions it gives your type, seemed accurate for me, ymmv)https://www.bodybuilding.com/fun/becker3.htm
figure out where you fall and then check for a weight chart that matches (you may be a mix, in that case just use common sense).
Chances are good that you dont need to be in the middle of that range, but closer to one of the ends. You can also find numerous estimators that take body measurements into account (chest, waist, arm circumference ect) to give you a tighter range. Remembering that they are still ESTIMATES and you may not match up exactly.
then you can figure out how much weight loss to target from there. And dont set it and forget it so to speak, keep an eye on how you are feeling, if you get too light you start to have other problems (energy drop off is a major one) which wont help your riding (or any other aspect of lift).
just trying to share stuff that i learned through my own experience, and would have been nice to know in advance, do what you want with it.
