qclabrat
You really expect a NYC hipster to wrench their own bike?Went to the SOHO store... and walked out with grease instead....
when they stop stopping, reallyHow often should normal people bleed their brakes? I could google this but, you know...forums
I ride stock Tektro, so it's hard to tell. JK. It's definitely time to figure out how to service my gearing. Some ugly shifting going on there. I might take the shop up on their supposed "first time it starts shifting bad just bring it in" free service, even though I want to figure it out.when they stop stopping, really
I've never serviced them till they weren't doing their job. Usually for me it's 2 twice a year, I don't ride much so not the norm
Theoretically you are correct, it is a closed system. Somehow dirt and moisture(and sometimes air) still gets in the system. Same as with cars and motorcycles(I guess anything with hydraulics), after a while it turns dark and gets compressible leading to a spongy feeling requiring a bleed/replacement of the fluid.it is a closed system - i've never bled the hopes (after giving away the elixr 5s - cause they had an issue, opposite the sram)
what changes other than pad wear?
can pad wear be compensated for (change in bite point) with a bleed?
Same as car brakes, I believe that spongy brakes are an indication of some even slightly failure of some components (i.e a seal that dried out, damaged line etc.) as well as improper installation / bleeding which could eventually lead to component failure or fluid contamination.Theoretically you are correct, it is a closed system. Somehow dirt and moisture(and sometimes air) still gets in the system. Same as with cars and motorcycles(I guess anything with hydraulics), after a while it turns dark and gets compressible leading to a spongy feeling requiring a bleed/replacement of the fluid.
Heat cycles will have an effect on brake fluid over time,or if you ride the brakes. Shelf life of an open can/bottle of fluid is very limited, weeks not months. If there is air in the system you will get cavitation which will give you a different feel at the lever as the ride goes on due to inefficient heat transfer. New brakes will need time to mate to surfaces so expect your new brakes to work to they're potential for a little bit.How often should normal people bleed their brakes? I could google this but, you know...forums
The sad thing is... there used to be 2 LBS that I could go to in SOHO. Bicycle Habitat and TOGO, but they have since moved.You really expect a NYC hipster to wrench their own bike?
The real answer is, you must bleed 2x a year... so you can mess them up and upgrade to better brakes. TRUTH!How often should normal people bleed their brakes? I could google this but, you know...forums
Welcome too my world hahaSo... Had 1 too many drinks last night so I was feeling lazy this morning. Went out to the garage to check on the RDO brakes and it felt nice and firm. Heck with another bleed and mounted them on the bike. WTF... its mush. I guess the position of the caliper matters. Reluctantly, take the caliper off the frame and bleed. Shit load of air comes out from the caliper end. Nice and firm but it's too firm! The lever feel from front to rear feels unbalanced! But at least it's working.
Oh.... of course during the process I guess a little oil got on the rotor because it's squealing like a pig. Just can't win....
so early decade, I actually like them over the blah blah black components everyday
