if they were MK3s...Buy my Flow EX's.![]()
Minions run small, but you already know thatI don't like the Hugo for + tires at all. I tried a 2.8 and 3.0 on Luke's Hugo and the rim is almost in line with the sidewall. Gotta be careful in the rocks. 35-40mm is probably optimal for 27.5+. The Flow's are great for the 2.5" Minion.
Minion DHF 2.5 and NN 2.6 are practically same size on 30mm RF rims.Minions run small, but you already know that
do you have the 2.5s with MK3s on the Chameleon? I'd like give that combo a try but I'm just about overspent this year
No, I have the factory RF wheels with 3.0 WTB's on the Chameleon. My Minions are on the Flow EX's in my shed, which used to be on the Bandit. Bandit has been on Crest MK3's for a while with 2.25" Racing Ralphs.Minions run small, but you already know that
I want to run 2.6 tires on the other SS
have Dirt Wizards on Hugos on the other bike and I really like the tire profile
would Dually's be too wide for 2.6 tires?
Kinda sorta, I'm curious to see how 40mm rims will compare with the Hugo's for the Dirt Wizards., that's for the Carver Gnarvester. Then there's the TransAm 29, which I've read fits a 2.8 on a blunt35. I just got some XR4 2.6 tires and will try with the Duallys first, if no good, will look for 30mm rims. At the end, I'll figure out what size rim works best for me for each bike. Got all winter to figure this one out. FUNSounds like your headed towards the 29+ end of the spectrum with wider rims and bigger tires. Will those fit on the bike? The other option might be wider 27.5 rims and tires which will net you something closer to the 29er diameter.
Do you have a 12x148 rear stans wheel?if they were MK3s...
Sorry nopeDo you have a 12x148 rear stans wheel?
I'd trade you my 12x142 arch mk3 rear wheel for it.
