Blk06CompIRL
Hey all, so i have a little story to tell. My bike (trek tarpon hard tail) came stock with bontrager LT3 2.00. I really do like this tire until i encounter rocks, roots or climbs that are a little muddy. After some research i decided on the bontrager XR4 exp 2.20, but after talking to the guy at LBS i purchased the 2.35. I mounted up rear wheel and FAIL rear tire side knobs hit front derailleur cage on smallest ring, which i was hoping to not be an issue. I spent some time and cant get the needed clearance. My 2nd issue came to when i went to bring my bike to work to mess with it and FAIL bike tires are to wide for my roof rail mounts (which i did not even think about) unless i drop PSI down to 10-15psi. i have two options as i see it A) see if i can return/exchange for the 2.20 or B) modify derailleur cage for clearance and inflate/ deflate tires every ride to transport.
I am currently thinking A) for making my life easier. The reason the guy at LBS suggested the 2.35 was because i told him i have issues with tire grip on rough terrain (even with dropping psi and weight shifting 5'11" 180lbs) i also wanted to upgrade so i had a tire to handle the rockiest / rootiest terrain i encounter for i will be using the same tire for everything. Personally weight and rolling resistance is not important to me i bike for fun and as a work out so im fine for pedaling harder to go faster. The only reason i would consider keeping 2.35 is if its truly worth it for overall performance on the rougher terrain and as i progress hopefully catch some air time. Sorry if that is wordy but i know details are important. No pictures to post of rubbing but its pretty much last 1/4" inch of derailleur cage pressing into about a 1/4" of side tire knobs, and no im not cutting the tires i rather mod the cage lol and i plan to keep the XR4 model not looking for other tire options as of now just sorting out thoughts and ideas before i over think the situation. THANKS!! final note i plan to ride anywhere my skills allow and adventure takes me so i will hit a wide variety of terrain.
