Dave Taylor
Rex kwan Do
This is probably a @UtahJoe or @Patrick question but the #1 SS raceday question is probably “what gear should I run?”. Ok, cool, now let my self mind fug you a bit…tires(I assume bike tires too) have an aspect ratio. On a car this is generally the middle # in the size(195/50-15, 50 is the aspect ratio). This basically tells you that the sidewall is 50% of the tread width. So on a tire where the tread is 195mm the sidewall height is very close to 97.5mm. Sure, this changes a bit with rim width, tire pressure and distributed weight but it’s a general way to measure tires. So if that same tire increases in width to 250mm now the sidewall is 125mm. So a 50 aspect ratio tire looks much different on a 395/50-15 tire vs say a 235/50-22 tire.
Ok, where am I going with this? The aspect ratio kinda doesn’t matter but it does. Basically, all things equal at Mohican 100 in 2020 I ran a 34-17 gear and a maxxis 29x2.1 aspen tire. Let’s say I run the same gear with an Aspen 29x2.4 how much is the gear/inches changing? I don’t have the old 2.1 anymore and theoretically I would need to mount each tire, draw a white line on the ground and tire, roll one complete revolution and then measure. Can one of you smart guys do this “on paper”? Essentially what I am saying is the 34-17 will probably be a slightly harder gear to pedal on the bigger tire.
