Sealant safe co2(or other gas) cartridge?
I usually get the valve pointed up, and sealant pooled in the bottom. Never had any problems with Bonty, or Orange Seal, though I did experience some separation with OG stans.
If you blast it right at the sealant, it can get hinky.
Aspen problems 🤣
If only this were a large.
Okay, I know you guys are joking, but we know SS is faster, so it could very likely shorten the viable lifespan of sealant.
MAybe use co2 when racing, but go with a mini pump when JRA ?
I keep one of these in the Farley’s frame bag…. It uses propane instead of co2. It’s allegedly “ok”.
From stans site:
Is Stan's sealant compatible with CO2?​
CO2 is best used in an emergency situation. If you have no other means to get your tire to seat, you can use CO2. However, we recommend that you let the CO2 out either after your ride, or after setting up your tire, and replace it with regular air. Prolonged exposure to CO2 can cause the sealant to separate and/or decrease the life of your sealant.
This seems like a great idea. Almost as good as using propane as a refrigerant (which it is excellent at)
From stans site:
How did you find this info
