2019 Trek Full Stache 8 Mt Bike (Med/17.5") **w/Carbon Wheelset** **SOLD***
Status
Not open for further replies.
Eddie Z
For sale is a Medium/17.5" 2019 Trek Full Stache 8 mountain bike. This is an AL frame, full suspension, "29 Plus" bike which includes a carbon wheelset. (Original AL Wheelset long gone). The bike is in excellent condition with a few minor cosmetic blemishes from normal light use, no major issues. The tires are set up tubeless, recently refilled w/Stans. The tires and brake pads are young. Brand new grips. Includes a dropper post. The Trek FS is a blast to ride, a bit like a monster truck. The beefy 29+ tires makes easy work of the Northern NJ rock gardens common around here. I used the bike infrequently, so it's not beat up at all. Nothing needs attention. Comes with 2 spare tubes. Bike is located in Denville, NJ. Cash/Local Pickup.
Specs from Trek website below:
Frame: Alpha Platinum Aluminum, ABP, Boost148, Knock Block steerer stop, EVO link, tapered head tube, Mino Link, Control Freak internal routing, down tube guard, G2 Geometry, 130mm travel Fork: RockShox Pike RL, Solo Air, Charger damper, tapered steerer, Boost110, G2 Geometry w/51mm offset, 130mm travel
Rear suspension: Fox Performance Float EVOL, RE:aktiv 3-position damper, tuned by Trek Suspension Lab, 210x52.5mm
Wheels: Front hub, Bontrager sealed bearing, alloy axle, Boost110.
Rear hub, Bontrager sealed bearing, Boost148
Rims: Line Pro 40 Carbon (Upgraded. not stock).
Tires: Bontrager XR4 Team Issue, Tubeless Ready, Inner Strength sidewalls, 120tpi, aramid bead, 29x3.00˝
Shifters: SRAM GX Eagle, 12 speed Rear
derailleur: SRAM GX Eagle, Roller Bearing Clutch
Crank: Truvativ Descendant 6k Eagle, 30T
Bottom bracket: PF92
Cassette: SRAM XG-1275 Eagle, 10-50, 12 speed
Chain: SRAM GX Eagle
Pedals: Not included.
Saddle: Bontrager Evoke 2, chromoly rails
Seatpost: Bontrager Line Dropper, internal routing, 31.6mm, 17.5: 125mm, 19.5 & 21.5: 150mm
Handlebar: Bontrager Line, 35mm, 15mm rise, 750mm width
Stem: Bontrager Line, 35mm clamp, 0 degree, 60mm length
Headset: Knock Block Integrated, sealed cartridge bearing, 1-1/8˝ top, 1.5˝ bottom
Brakeset: SRAM Guide R hydraulic disc
Weight: M - 15.37 kg / 33.88 lbs (with tubes)
Weight limit: This bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 300 pounds (136 kg).
Ooops! Fixed. Thx.
Darn. Even tho it’s not my size I was just hoping for you to correct it to 300 and I would be on my way to buy it. LOL.
Nice bike a Stache was on my want list last year but could not find one my size that wasn’t beat to shit ended up with a Timberjack which I love.
GLWS.
This really is an awesome bike, and I really really hate to ditch it. But I sprang for an E-bike, I have a 'Zero Sum gain" rule in my small garage..... One in, One out...
Status
