You can put it in with used motor oil, if you have any to get rid of. They take used oil at most auto parts storesBoth mineral oil and DOT. I'm talking small amounts from flushing and bleeding bike brakes.
What about the DOT 5.1 fluid used in SRAM hydraulic brakes?You can put it in with used motor oil, if you have any to get rid of. They take used oil at most auto parts stores
Why go that far? Easy enough to dig a hole in the backyard. Let it drain right right into the water table.I pour it into a bucket and dump it in the River when it's full. That's where it all ends up anyway...
brake fluid burns really well.
I like the colors the oil makes in the water.
They need something to justify a 7k aluminum bikeSo if I understand you correctly, we need to send all our used oils to Specialized in your care, so they can use it to make all the cool Oil Slick” components.
No, no. You got it all wrong. It’s just oil slick water…So if I understand you correctly, we need to send all our used oils to Specialized in your care, so they can use it to make all the cool Oil Slick” components.
