serviceguy
I built a new set of ‘summer’ wheels for my mukluk and I’m eager tu test the bike in the new 29+ setup (hoping for a better result than the fugitive in a 27.5+). The old wheelset uses a 197 fatback hub while the new one is built on Hope fatsno. I am running xt 11 speed 11-46t on both. Looks like the cassette on the new wheel is shifted to the right as compared to the old setup. I did install the ring that came with the hub between the cassette and the freehub, but again on my fugitive I can switch between Hope (with the ring) and DT Swiss hubs without touching the rear derailleur settings. I’m not even sure removing the ring will do, seems like the cassette is a full gear off the mark! Any pointers? Everything seems torqued down correctly, there’s no play on the cassette and massive clearance between the smallest cog and the frame. Maybe I mounted the older cassette wrong ? What is supposed to be the variance between the position of a cassette on different hubs, normally ?
