danxtj
First a little backstory
I recently bought Lou's (soulchild) Flash 29er. Full specs can be found here.
It's a great bike, highly customized, and light. I loved the bike from the first trail ride but something just felt a little off. Which brings me to...
Why
Compared to most people on this board I am not a overall fast rider. I am, however, a pretty good descender. In the races I have been in, I always seem to be among the fastest going downhill.
The only problem is the new Flash is a 1 x 9. Meaning ,for me, that I need the seat post as high a possible to give me max power. Don't get me wrong I was happy to get a 1 x 9 because it will make me stronger, faster. (no granny gear) But it made me a lot slower going down the mountain.
Some of you may be saying "Maybe you should just get used to riding like that." And you may have a point, but that's not really my riding style and it makes the ride less fun for me. If I'm not having fun at something I do in my free time I'm inclined to do it less.
So I thought how can I make this awesome bike make me work on the uphills and fly downhill.:hmmm: What about an adjustable seat post?
What I need in a adjustable seat post
1) 27.2 diameter. Not a lot of companies make a post in 27.2 so that limits the field.
2) Reliable. I don't want to miss a ride because my seat post is stuck down.
3) Simple. I don't want to have to worry how much PSI is in my seat post before every ride. I will. That's just how I am.
4) Weight. I kept weight in mind when comparing seat posts. (All adjustable seat posts are heavier than normal ones)
How the Gravity Dropper Turbo Stacks Up
1) 27.2 diameter: Yes
2) Reliable: I only have one ride on it so far so I personaly dont know yet. From all the reviews I've read this seat post received high reliability and customer service ratings. I think it will be reliable because of #3.
3) Simple: Yes. Its a mechanical post. It basically has a pin that goes in different holes corresponding to saddle height. No leaking seal problems because it doesn't have anything to leak. Air and hydraulics are not used.
4) Weight. The gravity dropper turbo is the lightest seat post Gravity dropper makes. The 4in drop is 20 grams heavier than the 3in drop. More on this in a minute.
5) I just remembered I didn't want the cable connected to the moving part of the post. The Gravity Droppers cable is connected to the non-moving part of the post
Install
The install was easy. It's just taking out the old post, swap the saddle to the new one, install new post, run cables, attach remote switch.
The only problem I had was the new switch interfering with the shock lock out switch. No big deal really. They send an extra remote switch mounting plate that I used to shim it up.
What comes in the package
Remote switch ( ugly but good )
Spacer
Placement rear view The scratches on the lockout switch were already there. The two switches are not rubbing.
Placement front view
Saddle mount
Rear Cable exit and mounting. Looks kind of ugly.
The seat post can also be installed with the cable exiting the front. Double ugly.
Operation
I got this post with a 1" drop and 4" drop option.
To move the post down sit (or remain sitting) on the saddle and push the switch.
To move the post up press the switch and stand up. If the switch is hit momentarily while I'm standing up the post will go to the 1" drop position. If I hold the switch the post will go all the way up.
The post will also go all the way up if I'm standing.
video go to 1:45
http://gravitydropper.com/sales-support/tool-tips/video-comparison/
My thoughts
The Gravity Dropper turbo is ugly and it makes my bike a little heavier. It also completely changed how the bike feels going downhill.
Seat all the way up:
No vertical or horizontal movement. The bike climbs great!
1" drop
Feels great on tech flat areas and tech areas where the trail is moving up and down suddenly.
4" drop
With the seat dropped all the way this 29er feels awesome going downhill! I can move my body around like on my 26er. But the grip! The stability! It feels like I'm move "inside" the cockpit rather than "on top" of the cockpit. That "inside" the cockpit feeling on a 29er is amazing.
The weight
Let's see. The new post (switch and cable) is 505 grams. The old post was 234 grams. The new weight minus the old weight = 271 grams or .6 pounds. increasing my bikes weight from 22.2 to 22.8. I think I can still handle that.
The Bottom Line
Manufacturer:Gravity Dropper
Product: Gravity Dropper Turbo Seatpost $299
How Long Used: 1 ride so far
Similar Products Used: only thing close was a quick release clamp
Overall Rating [1-10]: Holding off on a rating until I use it more, but initial rating 9
Positive: Simple, No vertical or horizontal play, FUN
Negative: Ugly
Why
Install
Spacer
Saddle mount
Operation
video go to 1:45
My thoughts
1" drop
4" drop
The weight
The Bottom Line
Negative: Ugly
