Need some input from Trek Fuel owners. For the past two years my 2020 Fuel EX has exhibited a tiny amount of play in the rear suspension. When the bike is stationary on the ground and I gently lift the saddle upwards I feel some tiny vertical play in the linkage. It’s not the wheel, nor the saddle itself. It is similar to the play I used to feel on my 2001 Intense Tracer, which was due to the DU bushings wearing out and requiring replacement from time to time. However in the case of my Trek I had the shock’s bushings replaced last year when I had it serviced and the symptoms remained. All the pivot points are properly torqued and there is also no lateral play in the entire linkage, only this slight vertical play. As tiny as the play is, I do notice it on rocky descents, it manifests itself with a slight knock or rattle when hitting rocks. I don’t, however, notice it on seated climbs.
So did a bit of googling and found this thread (unnecessarily harsh though it may be) that suggests it may be due to the bolt (that secures the shock to the linkage) not having a sufficient shoulder to take up the play. However this play was not evident when the bike was new.
I will take it to the LBS where I bought it but before I do wanted to see if anyone with a Fuel (or Slash similar Trek) has experienced the same issue and what it was due to.
Thanks
Thanks
