i gotta worry about watering that sod and that seeded back yard, good thing they leave the sprinklers behind for a little
The Raintrain is a great way to water your yard, instead of laying out a bunch of sprinklers. it is really slow though so keep that in mind. Just lay the hose in the pattern you want it to follow up to 200 feet and it will water up to 13,500 square feet. IT'S A SELF-PROPELLED SPRINKLER!
However, multiple sprinklers might be better if you are concerned with seed drying out in the hot NC sun.
He's a new southerner... he'll catch on.Good call, that's what the yard is for. Less mowing that way too.
I opted to ground the floor vs. ye ole muratic acid and deck brush. Going over old paint was a pisser.there's no way. it took me an hour to do my garage with epoxy.
I went with Epoxy-Coat from all the reviews I read. Buy 10% off lowes coupons found on ebay.
Yes you can then 10 years down the you rent a buffer and make it look like new again. It doesn't need buffing all that often unless you want a gloss finish.Seems like a lot of maintenance with polishing and stuff... can’t i just install this and not do anything with it
Super. I just want something better than the concrete. Where do you recommend shopping for these things? What brand? I don’t want the Quick-E-Mart version.Yes you can then 10 years down the you rent a buffer and make it look like new again. It doesn't need buffing all that often unless you want a gloss finish.
https://www.floorcity.com/products/...2hw4ZwMBcgSPJMvXyROFtS0lURdIzH9IaAgdBEALw_wcBSuper. I just want something better than the concrete. Where do you recommend shopping for these things? What brand? I don’t want the Quick-E-Mart version.
