Long shot here but am wondering if anyone has this kit from Frigidaire, perhaps on an older dehumidifier that you no longer need or use?
The gist of the issue is I have a Frigidaire dehumidifier that has an outlet for continuous drain into my sump well. Problem is, despite following the manual exactly, the unit only drains into the the bucket within the unit. It doesn’t drain to the hose attached to the unit.
I found this video, as well as other posts online, that confirms this is a common issue. The solution is this part (pictured). It is comprised of a rubber plug to stop water from going into the internal bucket and a vented elbow that facilitates water flow. Frigidaire no longer has them nor does Parts Select and every other website I’ve searched.
Anyone have one? If not I may try to MacGuyver something. Shame on Frigidaire for not supplying this to begin with. I called their help line and they couldn’t have been any more useless.
