Tire recommendation
Rockbottom
What type of tire would you recommend that is easy to install/remove? I am not running tubeless. Just purchased a Maxis Aggressor tubeless ready/folding and the tire was near impossible to mount onto my rim.
If you’re running tubes, are wired tires easier to remove/mount than folding tires?
cbiker
I run maxis tires and they are fine how often do you need to take your tires off that its an issue.
Rockbottom
Just replaced the tire recently (usually new tires every 1-2 seasons). Otherwise I just remove one side of the bead when I have a flat to put in a new tube.
Resetting the tire on the rim has been a monumental task. Even with a heavy duty tire lever
Top
