habskater11
For sale both front and rear calipers with rotors. These brakes came off my 2018 stumpjumper, used them all of last season. Pads still have life on them again will come with rotors. Rear brake line was cut when taken off due to internally routed so the tech said. Brakes feel great and the levers have adjustable reach. Scratch on one lever from a digger I took, other than that no other cosmetic / no mechanical issues.
Light Polygon Airflow Type (TR160-11)
High Heat Dispersion & Heat Tolerance
Diameter : Ø160mm
Weight : 116 Grams
Also Available : Ø180mm / Ø203mmLeverCast Aluminum Lever & Bracket
HD-M520 : Reach 86-90mm
HD-M521 : Reach 81-85mm
Two Pieces Hinged Bracket
Can Be Combined With Matchmaker® Or I-Spec®
2 Finger Blade
Short reach for Small Hand
Finish : BlackCaliperForged Aluminum Body
Free Angle Of Hose Connector For Varied Frames
Easy Pads Replace From Top
Finish : BlackPadsA10.11
High Performance Metal Ceramic compound
Easy Replacement
Also Available : Organic compoundFluidNon-Corrosive Mineral Oil
Excellent Heat Expansion PropertiesWeightFront Wheel - 300 Grams / Rear Wheel - 320 Grams
(Excludes Rotor, Adapter & Mounting Bolts)
Diameter : Ø160mm
Weight : 116 Grams
2 Finger Blade
Easy Replacement
