I heard Garmin is not made in the USA....ThanksObamaGarmin.
It wasn’t intended to but has migrated that way. The original issues have occurred over and over now. I guess need simple.God bless anyone willing to put up with this on a $300 device.Oh... ok... so this is just a Garmin hate thread? Gotcha.
It always sucks when you get a defective unit.It wasn’t intended to but has migrated that way. The original issues have occurred over and over now. I guess need simple.God bless anyone willing to put up with this on a $300 device.
Macbooks use usb type C. Which is what all new android phones and iPad pros use. You can get a type C to micro usb cable for less than 10 from Amazon.
Not worth it. I’m a blue collar guy that doesn’t want to spend a day setting the unit up. The bolt is so simple it’s awesome. Wish the nav issue didn’t work me up. Everyone I know says “yea, the garmin takes sone time to set yp and it can be frustrating”. Not for me.
The Bolt is much easier to set up with your phone.... like stupid easy.i mean my garmin took me all of 5 minutes to setup, i still think you either got a defective unit, or the problem is you. . . . . but to each their own.
it would certainly be nice if garmin would save your screen setups/settings and give you the option to copy them to a new device, but not a huge deal.
Yibambe!Dave - send it up to me, i'll mess with it.
If i can get it to record cleanly, you can sell it knowing it is working.
also lets me see if i want it, and can compare it to the elemnt....
I don't mind initiating the warranty replacement, if that is an option.
The screen setups thing is a bummer for sure, and it really shouldn't be an issue - Garmin Connect does save other profile information, like your age, weight, gender, and your bikes. Seems like it should be pretty easy to map your screen setup info as well, right?
6 of 8 rides the garmin has froze on me..
Close to 1 year ago, I went through the same debate on what to get Garmin v Wahoo. I had a Garmin 705 that worked pretty much as it should, with minimal issues. Yea it was old and I had to upload from a computer, but NBD. Fast forward and now I have an 830. Took a while to sync to my phone due to an iPhone 11 glitch, other than that its been great no issues.
I also have an 820 and its defintely buggy. The sheer number of firmware updates pushed since i bought it is evidence alone. Seems like every week there's a bug fix! I get the freezes, crashes, shitty battery life, awful touch screen lag and the most laughable is i cannot shut it off at the end of the ride! You hit the power off button and it only just reboots--you have to then do it a second time to shut if off properly. The first unit i bought woulnd't even pair with blutooth. Sent it back, replacement was the same! Turns out it was that stock firmware revision had a blutooth bug--had to do an update before it was even usable out of the box. *facepalm*
