02camaro
i have a 2018 pike rct3 set at 120mm of travel on my sb100 and it does not return back to full travel. i can manually pull it back and hear a hiss of air purge and it its normal but ill eventually have to do this again during a ride. i also used a zip tie to purge the air again but it still comes back. i pumped it up to max pressure and cycled the fork, basically tried all the tricks google told me. i took the fork apart to do a lower leg service yesterday to see if there was any extra grease hanging around. there was alot and i think i cleaned it up nice and put just enough on the air spring and other necessary areas this still did not fix this issue. i didnt remove the damper, i didnt want to have to bleed it.
someone tell me what im doing wrong to get this fixed, other than fire and buying a fox...
