Ironjunk
I generally can figure out most drivetrain issues. It's a 105 short cage from probably 2008. Says flight deck shifter , everthing is 10 sp.
My problem is when shifting up sometimes the shifter will click but i will have to give it a nudge to index properly as it's chattering trying to index.
It will click when dropping down and index in all the correct gears.
If i add tension then it won't want to drop properly to smaller gears.
The hanger is true. The cables are new and the shifters are clean and lubed. The derailluer is clean.
