A Potted Plant
Honorary Sod
Oil slicks and missiles?
This is a great follow!
@Patrick I think there's a new prob lol
@soundz thanks for the article. I spent probably an hour chatting with Crutchfield this morning and have a game plan now. Between your post, a couple of others, Crutchfield, and reading some articles I’m pretty comfortable I have some solid direction now. I will post up what there recommendations where later. Side note I’m curious about your van build.
You can pull the 2 front channels and distribute them over 6 (front rear sub) and if much hasn't changed the amp will take high(head unit speaker) signal and work fine. If not a lineout converter is an option.
2. Your payoffs for tweeters properly staged isn't worth the hassle unless you have taken other steps like deadning and other shit that isn't worth your time at this stage. When I take the doors apart I'm going to insulate them with wool and then put sound deadening around the speaker. I just have to figure out where to put the sound deadening for the speaker.
@soundz what made you choose JBL speakers? There are so many brands out there.
Yah so my audio experience is mostly from the PA world and we were using mostly balanced cables (hot, cold, shield). When I first replied, it didn't occur to me that you could take any speaker outs and dump it into another amp (with some conversion).
Guys at Crutchfield say this hands down as their favorite. https://www.crutchfield.com/S-v2eiQvKWZwo/p_13698103/JL-Audio-FiX-86.html@cdrmtbiker what DSP did you go with?
I'm not sure I'm getting it yet because tuning it might turn into a disaster.
I'm not sure about the Helix. They didn't mention it. I have to look into the tuning instructions before I get the DSP.You had me start dreaming up a system I didn't see it on their site but did they have a helix?
Btw see if there is auto tuning feature and tune with training wheels
Does anyone know what this wiring harness adapter is called? Is this standard in the automotive world and how do I find a plug that fits in the other end? This is a plug for pre-wired rear speakers under the drivers seat. Or maybe I just need some pinned wires to plug into the other side. If I can find something that will plug into this I will not have to cut any factory wires to do the install. I called the MB dealer and they looked but couldn't find anything. See attachments.
Thank you I'll check it out.It doesn't look like an exact fit, but I think this is along the lines of what you are looking for : https://www.hifisoundconnection.com...eplacement-Connector-Harness-Kit-HA-729301-35
