rlb
Has anyone used the Speedfil Speedflask bottles? I’m looking at insulated metal bottles and it seemed like a toss-up between Bivo and CamelBak until I came across the Speedflask. Based on the review below it seems the Bivo and camelbak have the same design, which includes the vent straw that I’m not too interested in dealing with if I can avoid it.
The Speedflask doesn’t have the tube and also seems to be slightly shorter in the 21oz size. It also has a covered mouthpiece which is a bonus, though Bivo has that as an add-on. Curious to see if anyone here has used the speedflask.
escapecollective.com
speedfil.com
drinkbivo.com
www.camelbak.com
Bivo vs. CamelBak: who makes the best insulated water bottle?
This is one instance where you want something that sucks more, not less.
Speedflask
Speedfil introduces the Speedflask. This is the original vacuum insulated stainless steel water bottle specifically designed for cycling. With double walled construction, this bottle will keep fluid cold for hours and fits into most standard water bottle cages. As simple as pushing a button. The...
21 oz insulated - Bivo Trio
Meet the Bivo Trio 21 oz insulated cycling bottle. The first insulated stainless-steel bike water bottle with a flow-rate designed for cyclists. Insulated bottle for 12+ hours for hot days on the bike. Cycling bottle has tactile exterior for superior grip and reduced rattle in bike cages. Patent...
22oz Bike Water Bottles - Podium Steel | CamelBak
Shop our 22oz bike water bottles. CamelBak Podium Steel bike bottles are built tough enough for any ride, and provides plenty of hydration for the long haul.
