A Potted Plant
Honorary Sod
I have a m7000 crank(SLX), what do I need to do to use it with a boost frame?
New cranks.I have a m7000 crank(SLX), what do I need to do to use it with a boost frame?
I used my older XTR crank on boost frame without doing anything than mess with the BB spacers.Now there a bunch of chainrings with different offsets to tweak chainline. Not, the chainrings move the chain my mm's, which is basically nothing.I have a m7000 crank(SLX), what do I need to do to use it with a boost frame?
That is only on the newer shimano cranks, however the main difference between the different widths of the newer cranks is the width of the axle of the crank. And yes, you can add spacers to move the crank out, it actually comes with spacers to do such.The Shimano cranks are different for boost and not boost, not sure if the spider can be swapped out for a boost one, but since the chainring are bolted from the inside you can't add spacers to move he chain line to the outside. With Race Face direct mount (cinch) you would have just changed the chainring.
I was looking at the M7000 series documentation, which is what the OP asked for. Different par numbers for boost and non boost. I don't know thisspecific crank, but where would you add spacers to make it boost if it wasn't?That is only on the newer shimano cranks, however the main difference between the different widths of the newer cranks is the width of the axle of the crank. And yes, you can add spacers to move the crank out, it actually comes with spacers to do such.
What @jimvreeland said, there is a spacer that fits the spindle and one that fits the bb cups. Both do the same thing.I was looking at the M7000 series documentation, which is what the OP asked for. Different par numbers for boost and non boost. I don't know thisspecific crank, but where would you add spacers to make it boost if it wasn't?
YesYou would need to move the crank 3mm out, does the Shimano axle allow you to do that?
That means you thread 3mm less into the non-drive side (or 6mm if you want to keep symmetry), in addition to up the Q-factor.
Stop over thinking it, it is 3mm.That means you thread 3mm less into the non-drive side (or 6mm if you want to keep symmetry), in addition to up the Q-factor.
Most likely he already doesnt have symmetry. Not sure I have had a mtb crank have the same spacers on both sides, ever.
Shimano's own instructions dont show the same amount of spacers on each side...
