Jumping Help?
mtn
Anyone be able to help me with jumping technique? YouTube videos only teach so much. Unfortunately it seems like the only sessionable tables are at mtn creek.
FrankV
Hard to explain it to someone when they are not with them. I’m still learning myself and I feel the best way is to have an experienced rider tell you what you are doing wrong instead of “how to do it”. Take a video of yourself and put it up here for everyone to criticize it. Might just help you
JPark
In theory the High Bridge jump trails would be perfect for you to practice jumping but they are actually pretty tight and challenging.
However, the first table-top on the blue trail is nice to practice on if you wanted to session it. The rest of the trail can be difficult to maintain your speed with all the doubles and tight turns.
  • Like
Reactions: don
Ian F
Last year I made a concerted effort to get my jumping mojo back (since I had lost it sometime when I was a teen over 30 years ago). What I did was spend a few sessions at Thunder Mtn in MA and rode Gronk (a blue level jump trail designed/built by Gravity Logic) until I got it. A few takeaways from that recent experience:
1. Pull up. This is a kinda "well, duh..." but it really was an epiphany moment for me. While a well built jump will arc you over it, you still need to be an active participant in the process. Just letting everything go can result in the dreaded "dead sailor" and a possible OTB landing.
2. Once in the air, move the bike around. This is sort of an extension of the above.
Do a little whip, pick the front wheel up and move it back down to catch the landing, or whatever.
Basically, the idea is you always want to be in control of the bike while in the air and not the other way around.
3. Don't be afraid of the lip. This is probably one of the harder ones. While it looks like you're riding towards a wall, in reality it's not. Sometimes it really helps to look at the jump from the side and you can often see how shallow the take-off angle actually is. Again, this one is kinda hard and really just takes time.
4. Personally, I prefer jumping with flat pedals. While I generally trail ride on clipless, riding flats forces better technique. But this can be personal preference. I know plenty of guys who jump fine on clipless pedals. I have an instinctual BMX background which kicks in when I ride flats, so for whatever reason I just jump better when on flats.
It's been a long time since I have ridden at Mtn Creek, so I can't really speak to their jump designs, but I know the Gravity Logic built jumps are very consistent and confidence inspiring. Plus, you can go to just about any park they've been involved with and know what the jumps will be like: Thunder, Killington, Windham, etc. are all about the same.
A big, long forgiving bike also helps. My Megatower is a stable platform for jumping and has a nice amount of travel for the occasional "oh shit..." moments.
Norm
Mayor McCheese
This is a big one that clicked for me this year. It really happened for me at Killington, when I just took my fingers off the brakes on the jumps. First, having my hands on the grips fully just gave me more control. Second, it prevented me from scrubbing speed which is just one's brain saying, "NFW, STOP IT NOW." Third, by moving the bike around a bit when things are perfectly fine, it allows you to be more ready when things aren't.
All that said I am sure I still suck at jumping. I just suck less now.
As for your #3 - by the end of any DH day I am better with that lip-fear but as soon as a few days pass, it comes back. It's really hard to get back to that level of trust.
Ian F
It definitely took me awhile but by the end of 2019, I was able to ride Gronk and clear the entire trail on my first run down the mtn. My gravity riding this year has been limited and "lip fear" definitely came back a bit when I was there this year. Granted, it didn't help I had completely F'd up the bike setup so every run was beating the crap out of me.
My biggest "F-Yeah!!!" moment was when I rode at Killington with a couple friends last year and after spending most of the day riding Blue Magic (which is similar to Gronk), we decided to ride Black Magic as our last run to see what it looked like. I managed to clear almost every jump on the trail on my first attempt. I think a lot of that is just trusting the trail builders and knowing they have built good jumps that won't kill you.
interesting - I learned a few simple grabs on my snowboard - it def helps stabilize during air time.
Intentionally reaching down (indy, mute) and coming out prevents landing on the wrong edge.
for the .5 seconds i'm in there air :D
JPark
I too had watched all the youtube tutorials on jumping but still couldn't figure it out. I eventually took a jump lesson at Killington.
These are the 3 mistakes I was making.
1. I was peaking over the jump - Wanting to see the landing area of the jump while on the ramp and it was causing me to shift my body forward, which is bad.
2. When you hit the ramp of the jump, the momentum wants to throw your body forward. I knew this, but what I was doing wrong is I was using my arms to push away and counteract this force instead of using my core and legs. This would put too much weight on the front of the bike. Like most things in MTBing, light on the hands heavy on the feet. Your body should be perpendicular to the angle of the ramp, completely opposite of climbing or descending on your bike.
3. When preloading the bike's suspension I had always assumed you did it at the same spot on the jump. But the location you preload changes depending on the size of the jump and your speed. I was usually preloading too late. Don't go nuts preloading, I would try too hard and throw off my balance.
As stated above, the Gravity Logic parks have much more user friendly jumps. The Mt Creek jumps tend to have very steep transitions with lips on the top.
Captain Brainstorm
This is all pretty fresh in my head since I helped my son all summer up in VT hitting tables and doubles. Back home we sessioned a bunch of drops in Ringwood yesterday, slightly different technique. Don't just pull up on the bars, you need to load the entire bike prior to the take-off, unloading while you go off the lip. Press down on the pedals with your feet just before your front tire hits the ramp, then pop off with a pull on the bars as your front tire hits the lip. This gives you height and distance, you don't even need to be going warp speed, if you time it right, you'll clear a table or double. If you don't do this, you stand a good chance of going nose-heavy, and that doesn't end well. My first ever attempt resulted in my riding a nose wheelie for 30ft before I ate shit so hard, my shoes fell off like Saul Rosenberg. I was very hurt about this. If you're going to crash, its better to crash after a rear-wheel landing. For drops, you just need enough speed for your rear wheel to clear the edge before you're front starts to drop, with a little pop from the bars depending on how steep the transition is. If its the old huck to flat, you need a bigger pop.
  • Like
Reactions: don
mtn
Thanks guys. Usually I try to absorb the jump too early by leaning forward at the lip rather than standing up and following the lip.
Just as clarification, if anyone would like to help in person, I'm willing to travel to a jumping spot that doesn't have doubles.
rick81721
Lothar
I find this thread interesting - I have zero interest in jumping. The other day I was at Nassau and there was a group of maybe 15 riders all at that jump there - they had to wait for me to climb up the switchback before they could resume their jumps. I told them - no way I'd do that - carry on!
mtbiker87
Hit a pump track and just focus on jumping the tables all day. PJ or West Milford are probably best. High Bridge/ Nassau gave it a good try, but for some reason they just don't seem to ride very well. At least for me anyway.
A Potted Plant
Honorary Sod
Isn't that the one I crashed on?
Soundguy
#SenditGuy
Best advise I ever got was to follow through the transition. When someone says “pull up” don’t think of it like yanking up on the bars, it’s more just keeping the front end up after it leaves the lip so the bike stays in line with the take off all the way through the transition. At bike parks the jumps are built proportionately to the speed of the trail, so trust the speed no brakes and follow through the transition and you will clear the jump. I can’t say the same for sketchy jumps built in the woods...
mtn
I hate to pay $50 for a day pass at creek, but I may do that. I think Ego trip has three consecutive tables with the fire road to walk up. PJ is local, but I think there is one table.
roc
Great advice, wish I had read this before I went to Killington a few weeks ago. Pull up is so important, I didn't on the first table and i landed a little on the front wheel, took my mojo away for several runs. I didn't crash, but i definitely had that adrenaline flowing, and not in a good way. I somehow started moving the bike in the air, and it definitely feels better.
Not sure how you get over that fear of the lip, that thing was in my head all day!
One other thing, speed is actually your friend. A few times I let it fly (for me), and landed on the other side, it was way smoother than going too slow and landing on the top of the table top.
I have found out, that I am more of a wheels on the ground guy. I would rather rip down the new white at ringwood or Skeezits in stephens than hit those table jumps all day. If only there was a chairlift at those places.
Ian F
I agree with that. Trusting the speed takes practice. Getting over the urge to grab a handful of brake as you're approaching what looks like a vertical wall takes time to overcome.
While it's not really apparent on the trail map, there is a "blue" line next to Lower Dominion at Mtn Creek that is good for learning/practicing on.
