How to tighten a 15mm thru axle lever
Ironjunk
I have a 15mm axle on a fatbike and the thru axle goes in and tightens. Then you are supposed to take the skewer and push it down to secure everything. My skewer just flops around and won't tighten. It kind of worked before but now not anymore.
There is typically a small screw (2.5-3mm?) hiding in the recess of the cam. Turn it clockwise a click or two, test, and repeat.
If it's not a Maxle, same thing, just make sure it's bloody tight.
