So I checked out the newly revamped Blue line on friday and was surprised that it was a complete rebuild. Kudos to the builders for taking that on. Had a lot of fun and wish i coulda stayed longer to dial it in, but here is my review after a bunch of full runs:
Pros:
- Fresh dirt used was better quality so it was much smoother and less gravely than before
- All the jumps are tabletops so no gaps to worry about clearing
- Lips were steep, but not too steep and very smooth and comfortable and didn't buck you
- The jumps are bigger but more straightforward than the old line so less thought and tech jumping skills required
- Lots of room between jumps and around the trail to pull out or stop if something goes wrong.
- It was a great to see a bunch of kids (and some adults) out there enjoying it and pushing and helping eachother.
Cons:
- Brake check or die. If you try to just roll the whole line without brakes you can overclear every jump which is dangerous and scary. On my proper DJ hardtail which carrys a lot of speed, I had to brake before every jump after the first 2 in order to actually hit the landings. Maybe full suspension would be different but braking so much on a jump line was new to me.
- The amount of brake checking also varies because each tabletop seems to be a different length and they're random and not proportional to speed or where you are in the line.
- I get that it's a public park and they can't make the jumps too big and if they did build them proportional to no-brake speed they would be insanely huge but I would have preferred they use the terrain or features to control speed instead of relying on braking.
I hope the green line gets revamped soon too because the surface is rough and gravely and there are some jumps and berms that need to be tweaked.
I haven't ridden the latest version but have been there and know the layout. Did they keep the same trail shape or were there re-routes? IIRC there were sections that you could gain speed up pretty quickly.
Great to hear the PROS as a lot of them are really important fixes. Smooth and comfortable and non-bucky lips are hard to do so that's a really good one as is better material.
From the shit I've built over the years it is really hard to get spacing to work especially for a multi-level public park. Some people can hit stuff at a crawl others need a good bit of speed. But we usually strive to set the speed at the first set that will work for the rest of the line.
I feel like for a downhill line it works well when gap sizes progress as the line goes downhill - more speed and you get more "warmed-up" as you go. When it's random size without an up-hill slope to shave speed it can be really tough to ride.
It's good to hear the updates and the fact that it's getting used a lot.
