THATmanMANNY
Previous owner says it fires up. I can’t get it to work and I following these directions. Any insight? Thanks
I knew you guys would save my day
Yes that little flame is the pilot
Gas is on (smell it when Pilot is lit
I followed that label instructions which is hold in pilot for one minute and then leave it on position two minutes.
I don’t think there is a thermo stat. Just the hi lo.
there is a wall switch for the blower/fan.. hmm
I just found this tucked underneath the unit. I don’t understand why step 9 says to turn off gas to main burner and knob back to pilot???
I see. My parents place has a gas fireplace and I can light that no problem. But maybe this one is busted. I googled Haugh’s ventless fireplace and said something like they do need to be inspected if they have issues. Maybe this is busted? Put a call in someone local.
although someone did write to light theirs they hit it on the side @mntal ill try again
Meant to post that day but I gave up tinkering. The fireplace repair quoted $150 for the visit/service. Not too bad to keep warm but looked into your comment. Looks like the copper tube goes up and I need to take it apart some to get to the other end inside the log area.The copper colored tube is the thermocouple. Take that out and clean it. Gas supply is the silver tube.
