Karate Monkey
Above, cleaning out unused/no-longer-useful stuff:
Garmin remote. Page screens, lap, and one set-able command.$35 $30
Wolf Tooth bolt-on axle for Rockshox. Fits current 110/15 forks.$30 $25
Rockshox Maxle Ultimate. Fits for same--110/15 current production.$40 $30
Nitto Technomic stem. Fits 1" threaded forks (22.2mm diameter). 25.4 bar clamp, 80mm reach extension. This is the 'long' Technomic, 165mm from minimum insert. $45
Shimano Alivio rear derailleur, RD-T4000-SGS. 9 speed, 34t max rear, total capacity of 45t. Unused, slightly smushed box.$35 $20
Lezyne chainwhip. Got wood? You can now. Has integrated hook for removing sprocket lockrings, with handle clearanced so you actually can. $20
Bontrager Line 35 handlebars. 35mm clamp, 730mm width (slightly cut down). $10
Wolf Tooth 2-slot B-Rad base. In retail packaging. $15
Wolf Tooth Dog-bone base and double-bottle adaptor. Screws in separate baggy. $30 for both.
Look for more items (particularly vintage items) in the coming weeks. Some of these items will be listed elsewhere.
Pickup/meetup between Hartshorne/Allaire/nearby areas.
Contact with any questions, etc.
