MikeyBikey2000
All I did was remove the wheel to put brake pads in.. took for a spin (previously drive train ran flawlessly), hit a climb and it would no longer get on to the highest cog, kept slipping between highest and second highest.. went home, threw on the stand, used the barrel adjuster and got it to seat right and seemed like all gears were hitting fine. Took out and hit it hard and there was a little play when cranking up a hill but now you can hear the derailleur not fully switching between like the 4-5th cog, and when there's pressure it will slip.. The sweet spot using the barrel adjuster is alluding me.. Wheel is on tight btw, I thought maybe there was a tiny bit of play. Anyone have anything I can check.. ready for fire.
