A Potted Plant
Honorary Sod
Got a square socket?
How big, you can get sockets for old-school square bolts
What’s old for a 350? Mine are an odd lot, 12x157 straight pull 18H center lock, 2018/2019 circa. Not the one from the spline wheel-set either (I do have one of those sets as a spare too).
My Bronson came equipped with DT 370 hubs, and while they work well, I would like better engagement. My old Hopes were nice, but I really like the DT 350’s that are on my Farley. I saw a few videos on Uboob that show folk upgrading pawl style DT hubs to ratchet and was wondering if anyone has done this, or failed at attempting it. I would really like to improve my wheel without buying a new hub and relacing or 🔥 thanks
Isn't it called a vise?Look at the drive ring. If you can see the outer diameter of the race completely, you don't need it. If you can juuust see the outer diameter of the race, you need the tool.
I dunno. Never needed to measure it since it wasn't important. 36mm? That's a popular size for bicycle stuff, for some reason.
This was discussed specifically with reference to using an impact wrench.Isn't it called a vise?
What a horrible design to have to take the ratchet ring out to change a bearing.I replace that bearing on my hubs at least once a year.
Guess you never worked on cars... nothing is designed for repairs, only to be easily assembled by the UAW OVERPAID brain dead workers.What a horrible design to have to take the ratchet ring out to change a bearing.
Waiting for what you think of the EXP design
Am I the only one that really likes EXP?
Does it require a special tool for the ring removal? Looks like a BB spline in the pictures but I never seen an EXP in the flesh.Am I the only one that really likes EXP?
So... about a hundred for the kitLook what I saw this morning haha
DT Swiss Ratchet LN greenlights DIY upgrade, kit converts pawl hubs to ratchet engagement
A simple new DT Swiss Ratchet LN upgrade kit will bring your low-cost DT wheels up to faster, stronger Star Ratchet high-performance standards!bikerumor.com
Another hundred for the engagement upgrade
Plus labor fees to LBS or cost of tools.
How much is a 350 rear hub?
Also the same tool price, 'round $80!Needs a tool just the same, it's just another tool.
The potential issue I see with the EXP is that while the surface contact between the two engaging rings is basically the same, the thickness of the two rings has now been considerably reduced in order to accomodate the bearing on the hub side and the spring on the drive side. Makes me wonder if someone with a very powerful stroke could crack the rings, but I'm also assuming DT Swiss making a few durability test before putting it on the market. I see that now it's available the 54T upgrade for the EXP as well.I am agnostic. It is a theoretically better design in every way, since you have to remove the drive ring to replace the bearings in the other hubs anyway.
I'm riding White Industries and Shimano (which is DT Swiss, anyway) currently. No opinion on the current stuff other than it's not in to be repaired as frequently as other people's stuff.
