.....Wally World sells a Bell HV for like $18 but reviews are mixed.
would be a good pump to just toss in the car and not worry about . . . .
I bought a california compressors oilless compressor and it’s super quiet.In the same boat, most times when I need the air compressor it’s after kid bedtime and the pancake is loud as heck. Tha said, the compressor came with a little schrader air chuck and with a .50 presta adapter it works fine. The only other thing I use it regularly for is non locking grips and occasionally putting air in the car tires.
Currently the reverse of you, I have the pancake but have sorta been looking at the HV pumps. Wally World sells a Bell HV for like $18 but reviews are mixed.
get an oiled compressor, much quieter than the little oilless guys that most people buy, (also a bit more $$$)
something like this guy https://www.harborfreight.com/8-gal-2-hp-125-psi-oil-lube-air-compressor-68740.html can be had with coupon for <$90 iirc. just make sure to keep oil in it :O
I went oiled on my 120vac/1HP 3 Gallon Craftsman for my condo. It's louder than my 220VAC 7.5hp Craftsman that's oil less I make sure to only let it kick on during the day when people are most likely not home.
Oiled oesn't always mean it's quieter...
I used to do the tube method to seat the beads and only unseat one side to get out the tube. However with modern tires I've been pretty much able to seat anything lately without even having to take out the valve core. Having a 3+ gallon tank at 120PSi allows high pressure AND volume so it push enough air to inflate the tire even if the bead is not set immediately and it'll catch and seat. Then there's enough flow to keep it going to get up to enough pressure to fully seat.
Where did you find a 220vac oilless compressor? 7.5hp is also a monster compressor, i would expect that to be loud bc its typically meant for more of a shop environment where noise doesnt matter. My 60 gallon is only 3 hp and moves 11cfm at 90psi.....still quieter than any oilless ones iv used.
