Thanks,
Read up a little more and it seems like I had corrosion. Cleaned it out and everything looks good. From what I read, it seems like the no grease on carbon thing is somewhat of an old wifes tale. Even Zinn is recommending that you grease the CF if installed into Alum or steel.
Tim
FSA Install Compound for Carbon Parts
Features and Information
* Prevents carbon components from slipping
* Tiny little plastic beads floating in gel paste
* Does not harden or dry out
* Little grit stuff so small you almost can't even feel it.
