Andypowerful
Need to replace my pads. Which is better metal or resin pads? I have Shimano SLX brakes.
this the the response i wanted to give but didnt feel like typing. i only use metallic pads and they dont instantly kill rotors, you will still get thousands of miles before they are close to being min thickness. my last set i got 2500miles on hope rotors with metallic pads beating the life out of them at the park.metallic pads handle heat better and last longer, at the cost of eating up rotors and less initial (cold) bite and some noise
resin pads are relatively quiet, wear a bit faster (but dont destroy the rotor as quickly) and bite right off the bat, but fade as they heat up.
most guys doing xc riding will run resin and downhill/enduro types with lots of high speed/steep downhill will use metallic. what type of riding do you do?
I know you didn't say it but the majority of the people make it seem metallic pads can kill rotors in a day. Not true. You can run metallic pads on "resin" rotors and still get decent life out of them.thanks for the agreement, also, i never said it was instant, but for comparison running resin pads i have close to 3k miles on my bike and am not even close to min thickness on rotors yet.
I've done that after seeing some pros do it when watching bike checks on pink bike. It felt good but I couldn't live with pads wearing at different rates.Run one resin, one metal in each caliper and its the best of both worlds problem solved! 🤣 But seriously more metal is always good 🤘🤘
you're supposed to replace rotors? 😂this the the response i wanted to give but didnt feel like typing. i only use metallic pads and they dont instantly kill rotors, you will still get thousands of miles before they are close to being min thickness. my last set i got 2500miles on hope rotors with metallic pads beating the life out of them at the park.
believe it or not if you ride hard enough, yes, but i cant imagine alot of people wear out rotors. id imagine most of them are replaced well before they are due so people can bling out their bikes with hope or ice tech rotors.you're supposed to replace rotors? 😂
