CrankAddictRich
So... I have two bikes now that allow me to swap wheels... a Specialized Fuse 6Fattie and an Enduro Comp 29'er. Both bikes allow the option to run either tire/wheel size, but I've got some questions about swapping around.
Currently the Enduro has SRAM Guide R's with 200mm F and 180mmR. It has an NX/GX drivetrain with 11 speed 10-42 cassette. The Fuse is set up with XT M8000 brakes and drivetrain.. 180mm F and 160mm R... XT cassette 11-42.
Assuming I convert the Fuse to 200/180mm brake rotors and get the correct rotor mount adapters would swapping the wheels be that simple? Will the different brake system calipers play nice with the different brand rotors? Will the different cassettes work with the different drivetrains?
Thanks in advance.
Thanks in advance.
