The Kalmyk
26 wheels still good for me
Ride my Niner then post
Ok, so what's the opinion if you have a intermediate bike with all 3 gears riveted together? Can you remove the 3rd gear still or just take a dremel to the teeth and use the 3rd gear as a bash guard that won't hang up on logs?
you know what else gives you more clearance???
So i am considering getting a bash guard. I have not used the largest ring since......so long i cant even remember. So i am willing to sacrifice those gears for a little protection. Even if its just the mental aspect of knowing i wont get caught up on any huge logs, rocks, or whatever, i want to try it.
So here is the question. I was debating replacing the stock 34 tooth ring in the middle with a 36 tooth to give me a little higher of a gear just in case i find myself flying down a hill looking for a higher gear...
Is this a bad idea? Am i missing something here?
Also, the ring i am looking at is 104mm - And all the bash guards i am seeing are only 104mm. So here is a dumb question. Will they fit with each other or do i need a bash guard bigger then the 104mm that is the chainring?
I vote for
A) learning how to hop logs as to not hit the ring in the first place.
B) get fit enough to actually use the big ring as a gear option like it was designed for
-Jim.
I vote for
-Jim.
I've returned to mountainbiking after a 10-year break. (My earlier experience was in college @ R. U. where I fondly recall buzzing the ecological preserve on my fully rigid trek 930 -- later stolen by some bastard-- followed by nursing my bruises with pints at Ale & Wich). Anyway, I just picked up a Monocog 29er -- back to being fully rigid for the time being -- and wanted to know what peoples' views are about installing bashguards on 32T single chainring. What works? What doesn't? (links to any recommended products are welcomed). Thanks!
