For $50 you could just drop it off and let me deal with it. I have a pile of tricks and a secret weapon.
Id stay away from easy outs in this case, they are great when the bolt is loose....but they are brittle and they snap really easily...They are also SUPER hard, so when you break then off, you are totally fucked....as @JDurk mentioned+1 for getting an extractor
GEARWRENCH Screw Extractor Kit 720DD - The Home Depot
The GearWrench Screw Extractor Kit is designed to remove broken studs and set screws. GearWrench is 1 the leading names in automotive repair tools. Packaging and Branding may vary between GearWrench andwww.homedepot.com
That’s what I thought. I’m not sure I want to bother now though.That's a wierd spot to crack.
Unlikely. I've been searching for the same exact NDS crank with no results. I did find a RF Next R NDS crank though...That’s what I thought. I’m not sure I want to bother now though.
I’m sure raceface won’t sell me a NDS crank arm though.
Time to dump RaceFace and go to Shimano.Edit. They may have a crack. Thoughts? View attachment 145419
I believe the Shimano pedal is what put him in this situation in the first place.Time to dump RaceFace and go to Shimano.
A pedal axle seized in the crank is quite unlikely to be the pedal's fault.I believe the Shimano pedal is what put him in this situation in the first place.
Well since we don't know the story of how he got here, we don't know if the spindle snapped first. I went through the same thing on a customer's stub of a spindle.A pedal axle seized in the crank is quite unlikely to be the pedal's fault.
Cross-threading, corrosion, over-torqueing, or lack of a shim washer where required are more likely candidates.
New cranks were the answer, as the customer wanted it asap.
