2018 Motobecane
Le Champion CF Inferno LTD
Has 1 ride on it, then i stripped the drive train and brakes.
$175
Didn't feel terrible, and i usually ride a 56 frame.
looks like this without wheels, handlebar, seat, drivetrain, or brakes.
This frame does not have cable stops for derailleurs. It has internal routing available for di2, or a full jacket rear cable (i think it could happen.)
specs are here
http://www.bikesdirect.com/products/motobecane/road_bikes/sram-etap-roadbikes-lechampcfinferno.htm
they had the frame only available up until last week - $450
Frame
AP2X Total Frame Design, Aero Section Downtube, New Semi-Compact Geometry, High Modulus Carbon Fiber Frame with replaceable derailleur hanger and 2xH2O brazeons
CARBON Tapered Headtube UPPER 1-1/8"/LOWER 1.5" (46x42/56x52.1mm) 125/130/140/150/170/190/210/230mm
NOTE: Rear brake cable routes internally through top tube. Derailler cables externally routed along bottom of down tube Some frames upgrade to more aero Di2/Wireless frame without DT der cable routing (No Choice).
Fork
Aero Carbon Pro High Modulus 700C CARBON ( 12K WEAVE ) FORK, STEM: ALLOY ( 1-1/8" TO 1.5" TAPER ) 215/220/230/240/260/280/300/320mm, CROWN: 56mm, ALLOY CROWN AND DROPOUT, BONDED CARBON BLADE, OFFSET:45mm
Headset
FSA Compressor, alloy top cap Fits 1 1/8" (28.6mm OD x 23mm ID) Tapered Steerers
Seatpost
RITCHEY WCS SINGLE BOLT/ZERO OFFSET, ALLOY TR741 3D FORGED, 31.6 X 350MM
STEM.EXT-6°) 110mm C/S:31.8/28.6x42mm ,BB BLK
i suppose i could weigh it if you really want to know.
$175
specs are here
Frame
Fork
Headset
Seatpost
