Welder Needed
M
MC San Andreas
Guest
Anyone know someone who does nice welding work on aluminum? My bike has a hairline crack on the swingarm that should be welded.
I tried to send a PM but it said "NJJess" was not a user... ???
We talking about the same Jess??? :rofl:
It's a different kind of quiet.
Besides, I wouldn't go teasing on a strong, capable chick who wields a blow torch if I were you. Uhm, unless you're into that sort of thing.:p
If you can't find anyone fairly local to you I might be able to get someone to do it for you. I work at a fabrication shop (in Baltimore MD) but I only mig and stick weld. There is a guy affiliated with my shop that is an excellent tig welder (we bring him in to do really high quality small stuff) and I might be able to get him in to do it. Consider what I'm offering kind of a last resort but if it comes to it let me know.
I apreciate the offer. I sent NJ Jess a PM but have not heard back from her yet.
most machine shop tig weld-- check your yellow pages and make some calls--sometimes you would be suprized what you find
First thing you have to do is find out what alloy the aluminum is, then figure out the weld process, pre-heat, post-heat, heat treat. Or else you can ust wing it and hope for the best. If Jess doesn't get back to you shoot me a PM.
In a nutshell:
6000 series: fix and re-heat treat.
7000 series: you're pretty much SOL.
http://www.frankthewelder.com/
He's in VT, so you'll have to mail the frame to him... and I doubt he's the least expensive option... but there's no one I'd trust more to fix an aluminum mtn bike frame.
Hi there
Sorry, but I've been working a lot,..welding at Giant Stadium and the Ferris wheel at Xanadu. Thanks for considering me to help, but alas I do not have a mig/tig welding machines at my job. I mostly do stick and wirefeed. The tig welding I did was at a warehouse doing fabrication/production. Besides, you really want a bike welder,..there is a women in NYC that builds frames. welding tubes (pipes) requires a jig to avoid deflection. The earliest I can get her number would be monday. Get back with you later.
In a nutshell:
Agree about getting FTW to do the work. It'll be done right and if he thinks a small gusset or something would help the stressed area he could add it and has the knowledge of what will work.
