Excuse me for my lack of knowledge...I have a set of Bontrager XDX Tubeless ready tires 29" sitting in my garage,if I matched these to my rims currently on my bike(WTBSpeedDisk29) can I go tubeless and what do I need to get to make this tubeless.
Yep, Stan's it and forget it son. There really isn't a true "tubeless" 29er rim on the market, most of them use some type of rimstrip/valve/sealant anyways. And on the other side of that, there really isn't a true "tubeless" 29er tire either, they all require some type of sealant as well...
http://highgearcyclery.com/page.cfm?PageID=587&action=details&sku=RS5505
-Jim.
crossmax29?
We used the Stan's No tubes CX kit with the new Hutchinson Bulldog CX Tubeless ready tires.
SWEET bike Larry!! I love the Con Crosso, I may get one when I get my soul back from Trek
I've been eying up that Stan's CX kit. Jay, does it look like the bead could roll and burp? Almost everytime I ride my CX bike I roll my tire away from the bead, not enough to flat, but enough to get grass stuck in my wheel, I wonder if it'd be enough to make the Stan's burp? Maybe I'll order it and try it out anyway...
-Jim.
Sounds like you like it better than the current setup on my 29er.:hitsfan:I spent some serious time today playing with this setup.
I think the key is to build up some tape and/or rim strip until you can barely get the tire on.
These tires have a very tough bead. I don't think they will stretch at all. I would NOT try this with a standard tire.
I used the rubber rim strips with 2 layers of stan's yello tape underneath. This is also on a Elite wheelset that has no eyelets.
I doubt you could burp it easily unless you run 30 psi or less.
I will be riding it this week myself but as of now i see little downside to this system other than thankless setup time.
J_
I built Larry (C. Puncher) a salsa cross bike today.
This setup looks sweet. In my book it might be better than tubulars.
I am curious to see what Jim says about this setup???
Have a looksee:
But on the other hand, I do have a question: I have a tubeless tire. There is not harm running it with tubes inside right? It's just like a regular tire right? What makes a tubeless tire any different than a regular tire besides the no tube part.
