Book of Paul H
Congrats! Did you dish them and trued them as well? What size are the wheels? QR ? Can I stop by with my swingarm to check the clearance?
Yep.... dished and trued.
The wheel is 700c 21mm internal width. I think I am pretty set on getting 40mm or 42mm tires for this. I think it will make a good long distance cruiser.
You're old school. Vreeland uses linseed. Just use linseed. I wouldn't have built wheels if I had to carefully apply antiseize on thread and lube on nipples. Too much work.
I used a spare spoke to thread the nipples, so the spoke took a dip in a lid of linseed and was screwed onto the spoke so the nipple and thread was taken care of in one step.
Carefully? I'd apply it with a 4 inch paint brush and hose it off
Jotting down some notes for Fred...
27.5 with 2.25(57mm) tires has circumference of 2194mm (698.7261mm 27.5in diameter)
700c with 40mm tires has circumference of 2205mm (702.2293mm 27.64" diameter) difference of 0.13"
700c with 44mm tires has circumference of 2230mm (710.1911mm 27.96" diameter) difference of 0.45"
700c with 50mm tires has circumference of 2268mm (722.293mm 28.44" diameter) difference of 0.93"
700c with 56mm tires has circumference of 2306mm (764.3949mm 28.91" diameter) difference of 1.40"
Errr... 700x43 Panracer?
I did it! Called in sick to work but I did it... took me 8hrs and the rear wheel had to be laced 3 times but I did it!
