jklett
Different distances from different riders on the same ride. I know that it really doesn't matter that much but it drives me nuts.ok we killed this discussion...whats the next strava bug to fix?
I don't get privacy/request to follow for anyone other than women.
What tranny issues? Doesn't show on consumer reports last 3 years - all "much better than average". Subaru is #1 brand this year. Wouldn't consider a volvo.
...Had the oil consumption issue fixed.
Having driven a Forester for 7 years now, no complaints here. Had the oil consumption issue fixed. No tranny issues at all. Unfortunately boring to drive because it’s almost too safe.
What did that entail?
Oil consumption? That sounds strangely familiar. Get a new motor??
They gave me a new short block assembly. Subbies use a real low weight oil and it was burning off. They addressed it now. And I have half of my engine brand new. So I’ll take it. It was a recall they did a couple years ago.
Good deal! Did they change the recommended oil weight? Honda is using 0W20 now, as are most mfg's I believe...
I did it with the 3 Garmin's I mentioned and the Oregon was the cleanest looking (not jagged lines).wheel sensor and settings make a big difference.
i think i'll go for a mtb ride with my watch, phone, elemnt recording... then i can always pick the longer/faster one.
So you mean to tell me that different devices will give different results?wheel sensor and settings make a big difference.
Yes, a few things in play:So you mean to tell me that different devices will give different results?
I knew about GPS only being accurate to a few yards but I honestly did not know that there were different sample rates, that explains what I'm seeing. Seriously, thank you!]
One, recording settings, how often the gps grabs a point. At some place like six mile, you have 100 little turns. If your sample rate is less often then your buddy, you gps trail will miss all those little turns, which can be up to a mile less the full loop. Gps accuracy comes into play here too.
Wheel sensor makes it pretty balls on as you can adjust the roll out length of the wheel by the mm. I have one on both my road bikes, but people don’t typically run a wheel sensor on mtb.
This is the garmin 520:I knew about GPS only being accurate to a few yards but I honestly did not know that there were different sample rates, that explains what I'm seeing. Seriously, thank you!
