Haven't been in a while, but hears as of Tuesday night it was fine.Hi, does anyone know current conditions? Thanks
And welcome aboard!
Should be fine especially with all the freezingHi, does anyone know current conditions? Thanks
Was there evidence of water that would likely become mud when the temperatures rise above freezing (in particular, in the afternoon)?Agree, trials were perfect this morning. Frozen and clear.
Dave,Super fun today, a little powder with some icy spots under. The tech blue trail had a really neat frozen waterfall effect from the uphill spring. Get some before the thaw!
View attachment 86931View attachment 86932
Umm.. what going to happen when temps warm up tomorrow? Supposed to be about 30 degrees tomorrow morningDave,
Is that near the boiling spring?
Last I checked 30 is still below freezing. We will have frozen tundra.Umm.. what going to happen when temps warm up tomorrow? Supposed to be about 30 degrees tomorrow morning
30 is air temp.Last I checked 30 is still below freezing. We will have frozen tundra.
Dave,
I believe that's called sublimationI think.... which is why ice and snow on the ground melts even tho air temps are at freezing.
30 is air temp.
Ground temps are usually higher in winter as it retains heat better than air..... I think.... which is why ice and snow on the ground melts even tho air temps are at freezing.
Boiling Spring is an actual spring in the park. It’s the name of the spring.30 is air temp.
